gunnark
Aug 07, 2014Aspirant
Pro 6 disk replacement yields unexpected size
Hi! I have an old Pro 6 with current firmware and a single FlexRaid 2 volume. I have replaced a 1TB drive with a 3TB drive in order to get a bit more space. I went from: 3 x 1 TB 2 x 1.5 T...
mdgm-ntgr
Aug 07, 2014NETGEAR Employee Retired
Can you go to support.netgear.com, click on the Contact Us link and select the email option.
Then when you have a case open, attach your logs zip file (Status > Logs > Download all logs) and post your case number here?
