gunnark
Aug 07, 2014Aspirant
Pro 6 disk replacement yields unexpected size
Hi! I have an old Pro 6 with current firmware and a single FlexRaid 2 volume. I have replaced a 1TB drive with a 3TB drive in order to get a bit more space. I went from: 3 x 1 TB 2 x 1.5 T...
Aug 07, 2014Guru - Experienced User
Frontview reports space in TiB (1024 multiples) not TB (1000)
In TiB units, the expansion is from 5.45 to 6.36 (not accounting for overhead and OS space). This is the same as 6 TB to 7 TB, just different units.
Is that you are seeing?
