alexs2012
Nov 29, 2012Follower
pro 6 fails to expand volume
Hi, I'm running a ReadyNAS Pro 6 , firmware vsn 4.2.22 I purchased an empty chassis and over the last few months have expanded the X-Raid2 volume by adding new disks 1 at a time. I'm using Samsung ...
Mar 17, 2013Guru - Experienced User
Look on the volume settings page ("status: redundant")
You can of course start with 4x3TB drives if that will hold your data comfortably. If you exceed 80% capacity, it is a good idea to add another disk.
