fastfwd
Apr 14, 2016Virtuoso
Pro 6 running OS4 - Convert RAID5 to RAID6
My Pro 6 held 5 drives (2TB, 3TB, and 3x4TB) in a single-redundant array (3 layers: 8TB, 3TB, and 2TB). I added a 6th drive (4TB) and chose to use it for dual-redundancy rather than increased capaci...
- Apr 14, 2016
- Generally you'd do the conversion to RAID-6 with a single layer array
- That should work. Check to make sure the partitions are all the same size for the devices in that layer and the SMART stats of the disks first. Is your backup up to date? If not, you may also wish to update that.
- No. This is mdadm and that's the command to use. Note: you shouldn't try shrinking a layer as that would lead to data loss.
mdgm-ntgr
Apr 14, 2016NETGEAR Employee Retired
fastfwd
Apr 19, 2016Virtuoso
Thanks again, mdgm. The NAS just finished restriping the final layer. Now the whole array is RAID6 and I feel a lot more confident that it'll survive the upcoming expansions from 11TB to 13TB and then to 16TB.
- fastfwdApr 19, 2016Virtuoso
.... from 11TB to 13TB and then to 16TB.I mean, from 13TB to 14TB and then to 16TB.
