fastfwd
Oct 16, 2023Virtuoso
Pro 6 running OS6: Array doesn't automatically expand
I'm trying to expand one of my old 6-bay NAS boxes by replacing four of its drives with larger ones: Started with a Pro 6 running OS 6.10.9, with six 4TB drives in XRAID RAID6 for a "16TB" (real...
Sandshark
Oct 17, 2023Sensei
It sounds like XRAID isn't enabled. In order to get your NAS at RAID6, you likely disabled XRAID. Did you re-enable it? Since the NAS is not recognizing your volume as being "expanded", you should still be able to do so.
If it is enabled, then there are some commands you can issue via SSH that may kick-start the process. But you should not try them until you've verified XRAID is on. Once a second layer is created and you have an "expanded" volume, you'll no longer be able to turn on XRAID. So I can give you those commands once you've verified XRAID is enabled.
Oct 17, 2023Guru - Experienced User
Yeah, makes sense to check that first.
It's easy to do - if you see a green stripe on the XRAID control on the volumes page, then it is enabled.
- fastfwdOct 17, 2023Virtuoso
Thanks for the help so far.
I've rebooted the NAS a couple times, but that has had no effect.
XRAID is definitely enabled:
- StephenBOct 17, 2023Guru - Experienced User
First see if the sdX4 partitions have been created on all four of the 8 TB drives.
There is no fourth partition:
# ll /dev/sd*
brw-rw---- 1 root disk 8, 0 Oct 16 08:03 /dev/sda
brw-rw---- 1 root disk 8, 1 Oct 16 08:03 /dev/sda1
brw-rw---- 1 root disk 8, 2 Oct 16 08:03 /dev/sda2
brw-rw---- 1 root disk 8, 3 Oct 16 08:03 /dev/sda3
brw-rw---- 1 root disk 8, 16 Oct 16 08:03 /dev/sdb
brw-rw---- 1 root disk 8, 17 Oct 16 08:03 /dev/sdb1
brw-rw---- 1 root disk 8, 18 Oct 16 08:03 /dev/sdb2
brw-rw---- 1 root disk 8, 19 Oct 16 08:03 /dev/sdb3
brw-rw---- 1 root disk 8, 32 Oct 16 08:03 /dev/sdc
brw-rw---- 1 root disk 8, 33 Oct 16 08:03 /dev/sdc1
brw-rw---- 1 root disk 8, 34 Oct 16 08:03 /dev/sdc2
brw-rw---- 1 root disk 8, 35 Oct 16 08:03 /dev/sdc3
brw-rw---- 1 root disk 8, 48 Oct 16 08:03 /dev/sdd
brw-rw---- 1 root disk 8, 49 Oct 16 08:03 /dev/sdd1
brw-rw---- 1 root disk 8, 50 Oct 16 08:03 /dev/sdd2
brw-rw---- 1 root disk 8, 51 Oct 16 08:03 /dev/sdd3
brw-rw---- 1 root disk 8, 64 Oct 16 08:03 /dev/sde
brw-rw---- 1 root disk 8, 65 Oct 16 08:03 /dev/sde1
brw-rw---- 1 root disk 8, 66 Oct 16 08:03 /dev/sde2
brw-rw---- 1 root disk 8, 67 Oct 16 08:03 /dev/sde3
brw-rw---- 1 root disk 8, 80 Oct 16 08:03 /dev/sdf
brw-rw---- 1 root disk 8, 81 Oct 16 08:03 /dev/sdf1
brw-rw---- 1 root disk 8, 82 Oct 16 08:03 /dev/sdf2
brw-rw---- 1 root disk 8, 83 Oct 16 08:03 /dev/sdf3
brw-rw---- 1 root disk 8, 112 Oct 16 08:03 /dev/sdh
brw-rw---- 1 root disk 8, 113 Oct 16 08:03 /dev/sdh1
brw-rw---- 1 root disk 8, 128 Oct 16 08:03 /dev/sdi
brw-rw---- 1 root disk 8, 129 Oct 16 08:03 /dev/sdi1
brw-rw---- 1 root disk 8, 144 Oct 16 08:03 /dev/sdj
brw-rw---- 1 root disk 8, 145 Oct 16 08:03 /dev/sdj1
brw-rw---- 1 root disk 8, 146 Oct 16 08:04 /dev/sdj2
brw-rw---- 1 root disk 8, 160 Oct 16 08:03 /dev/sdk
brw-rw---- 1 root disk 8, 161 Oct 16 08:03 /dev/sdk1
