cerjzc
May 19, 2017Tutor
Pro 6 won't boot up after going from 6.7.1 to 6.7.3
Upgraded my pro 2 from 6.7.1 to 6.7.3 beta without any issues, but tried my Pro 6 a bit later and it appears to have not gone well. It showed upgrading FW on the screen for a long time and from the ...
- May 19, 2017
Yes you had the same problem. It should now be fixed.
Edit:
If you have updated to 6.7.3 and ran into this issue please try USB Boot Recovery (note for those using RAIDiator-x86 systems such as the Pro 6 you'll need to use the RAIDiator-x86 4.2.x USB Boot Recovery tool with the OS6 firmware renamed to RAIDiator-x86-something) with ReadyNAS OS 6.7.4 which is now available!
If you have not yet upgraded please upgrade to 6.7.4 rather than 6.7.3. If your system has already been fixed I would still suggest updating to 6.7.4 the normal way using the web admin GUI.
cerjzc
May 19, 2017Tutor
Just as an update to this. I did bring it up in Debug mode and it is displaying "no ip address" on the display, but in Raidar 6.3 it does show up and that it is in Tech Support mode. It also shows it is on 6.7.3-T283 and does show the IP 192.168.168.168 for both IPs. Not sure if that is normal or not.
Thanks
- cerjzcMay 19, 2017Tutor
After a bit more digging via ssh I think I might be having the same problem as noted here:
Filesystem 1K-blocks Used Available Use% Mounted on
udev 10240 4 10236 1% /dev
/dev/md0 4190208 1144380 0 100% /
tmpfs 2018872 8 2018864 1% /dev/shm
tmpfs 2018872 16964 2001908 1% /run
tmpfs 1009436 8 1009428 1% /run/lock
tmpfs 2018872 0 2018872 0% /sys/fs/cgroup
/dev/md126 11696688832 5317807976 6377199192 46% /data
/dev/md126 11696688832 5317807976 6377199192 46% /apps
/dev/md126 11696688832 5317807976 6377199192 46% /home
root@CalvCoNAS:/mnt/var/cores# btrfs fi df /
Data, single: total=3.57GiB, used=580.03MiB
System, DUP: total=8.00MiB, used=16.00KiB
System, single: total=4.00MiB, used=0.00B
Metadata, DUP: total=204.56MiB, used=12.75MiB
Metadata, single: total=8.00MiB, used=0.00B
GlobalReserve, single: total=512.00MiB, used=320.25MiBroot@CalvCoNAS:/mnt/var/cores# btrfs fi usage /
Overall:
Device size: 4.00GiB
Device allocated: 4.00GiB
Device unallocated: 0.00B
Device missing: 0.00B
Used: 605.56MiB
Free (estimated): 3.00GiB (min: 3.00GiB)
Data ratio: 1.00
Metadata ratio: 1.96
Global reserve: 512.00MiB (used: 320.25MiB)Data,single: Size:3.57GiB, Used:580.03MiB
/dev/md0 3.57GiBMetadata,single: Size:8.00MiB, Used:0.00B
/dev/md0 8.00MiBMetadata,DUP: Size:204.56MiB, Used:12.75MiB
/dev/md0 409.12MiBSystem,single: Size:4.00MiB, Used:0.00B
/dev/md0 4.00MiBSystem,DUP: Size:8.00MiB, Used:16.00KiB
/dev/md0 16.00MiBUnallocated:
/dev/md0 0.00BI found there was a /var/cores/core-smdb file, but I'm unable to move or remove anything as I just get the message "No space left on device". The other post mentions that Skywalker was able to fix the root fs, but it doesn't mention what was done.
I did also try to download the logs, but it failes most likely because of the space issue as well.
Thanks,
Jeff
- mdgm-ntgrMay 19, 2017NETGEAR Employee Retired
I see what Skywalker did. I've replied to your PM.
Edit:
