Rick6922's avatar
Rick6922
Luminary
Jan 13, 2019
Here we go again
just updated my xr700 to new fireware about an hour ago. will not stay conected to the xbox1x AGAIN.... [UPnP set event: add_nat_rule] from source 192.168.1.8, Sunday, January 13, 2019 13:44:51 [UPnP set event: del_nat_rule] from source 192.168.1.8, Sunday, January 13, 2019 13:44:48 [DHCP IP: 192.168.1.8][Device Name: XBOXONE] to MAC address 2c:54:91:99:2a:10, Sunday, January 13, 2019 13:44:47 [DumaOS] DHCP lease change., Sunday, January 13, 2019 13:44:47 [DumaOS] DHCP new event., Sunday, January 13, 2019 13:44:47 [DumaOS] config write 'com.netdumasoftware.devicemanager.database', Sunday, January 13, 2019 13:44:47 [DHCP IP: 192.168.1.8][Device Name: XBOXONE] to MAC address 2c:54:91:99:2a:10, Sunday, January 13, 2019 13:44:45 [DumaOS] DHCP lease change., Sunday, January 13, 2019 13:44:45 [DumaOS] DHCP new event., Sunday, January 13, 2019 13:44:45 [LAG] Active lag now, Sunday, January 13, 2019 13:44:42 [DumaOS] config write 'com.netdumasoftware.devicemanager.database', Sunday, January 13, 2019 13:44:32 [Internet connected] IP address: 24.95.165.47, Sunday, January 13, 2019 13:44:20 [Internet disconnected] Sunday, January 13, 2019 13:44:18
  • [UPnP set event: add_nat_rule] from source 192.168.1.8, Sunday, January 13, 2019 13:44:51 [UPnP set event: del_nat_rule] from source 192.168.1.8, Sunday, January 13, 2019 13:44:48 [DHCP IP: 192.168.1.8][Device Name: XBOXONE] to MAC address 2c:54:91:99:2a:10, Sunday, January 13, 2019 13:44:47 [DumaOS] DHCP lease change., Sunday, January 13, 2019 13:44:47 [DumaOS] DHCP new event., Sunday, January 13, 2019 13:44:47 [DumaOS] config write 'com.netdumasoftware.devicemanager.database', Sunday, January 13, 2019 13:44:47 [DHCP IP: 192.168.1.8][Device Name: XBOXONE] to MAC address 2c:54:91:99:2a:10, Sunday, January 13, 2019 13:44:45 [DumaOS] DHCP lease change., Sunday, January 13, 2019 13:44:45 [DumaOS] DHCP new event., Sunday, January 13, 2019 13:44:45 [LAG] Active lag now, Sunday, January 13, 2019 13:44:42 [DumaOS] config write 'com.netdumasoftware.devicemanager.database', Sunday, January 13, 2019 13:44:32 [Internet connected] IP address: 24.95.165.47, Sunday, January 13, 2019 13:44:20 [Internet disconnected] Sunday, January 13, 2019 13:44:18
  • [UPnP set event: add_nat_rule] from source 192.168.1.8, Sunday, January 13, 2019 13:44:51 [UPnP set event: del_nat_rule] from source 192.168.1.8, Sunday, January 13, 2019 13:44:48 [DHCP IP: 192.168.1.8][Device Name: XBOXONE] to MAC address 2c:54:91:99:2a:10, Sunday, January 13, 2019 13:44:47 [DumaOS] DHCP lease change., Sunday, January 13, 2019 13:44:47 [DumaOS] DHCP new event., Sunday, January 13, 2019 13:44:47 [DumaOS] config write 'com.netdumasoftware.devicemanager.database', Sunday, January 13, 2019 13:44:47 [DHCP IP: 192.168.1.8][Device Name: XBOXONE] to MAC address 2c:54:91:99:2a:10, Sunday, January 13, 2019 13:44:45 [DumaOS] DHCP lease change., Sunday, January 13, 2019 13:44:45 [DumaOS] DHCP new event., Sunday, January 13, 2019 13:44:45 [LAG] Active lag now, Sunday, January 13, 2019 13:44:42 [DumaOS] config write 'com.netdumasoftware.devicemanager.database', Sunday, January 13, 2019 13:44:32 [Internet connected] IP address: 24.95.165.47, Sunday, January 13, 2019 13:44:20 [Internet disconnected] Sunday, January 13, 2019 13:44:18        is this styem log saying its deleting the nat rule?  if so  whats that mean?
    • Netduma-Fraser's avatar
      Netduma-Fraser
      NetDuma Partner
      It's frequently renewing LAN IP address for the device. Set a static IP for the device and also set a static WAN IP for the router itself
      • Rick6922's avatar
        Rick6922
        Luminary
        i just type the ip address into the xbox to do that on the xbox right?
  • FURRYe38's avatar
    Is Instant ON enabled on the console? If it is, disable it.
    • Rick6922's avatar
      Rick6922
      Luminary
      no its off. lol
  • FURRYe38's avatar
    Do you have a IP address reservation set for the game console? This is recommended.
    Is the console wireless or wired to the router?
    Beamforming enabled. Disable MIMO. IF you see Fast Roaming or 802.11k, disable this. Maybe found under router IP/debug.htm
    What MFr and model# ISP modem is the XR router connected too?
    • Rick6922's avatar
      Rick6922
      Luminary
      I have the ips reservation . I went through all that the first time. my modem is the NG cm1000. the other things you sugested i dont know how to do.It was working fine till i upgraded to new fireware .
        Netduma-Fraser
        NetDuma Partner
        WAN and LAN reservations? If it occurred when upgrading to the new firmware go back to the old firmware and see if the issue occurs again please. Also disable IPv6 in Advanced Settings.
    • Rick6922's avatar
      Rick6922
      Luminary
      [DoS Attack: ACK Scan] from source: 199.16.156.58, port 443, Sunday, January 13, 2019 15:36:04 [DoS Attack: ACK Scan] from source: 199.16.156.75, port 443, Sunday, January 13, 2019 15   DO YOU NO WHAT THIS MEANS IN THE SYSTEM LOG?
      • FURRYe38's avatar
        When you did the FW update, did you download the FW file then apply it then continue? Or did you do a factory reset and setup from scratch? You might do a factory reset and set up from scratch.
         I would power OFF the modem for 30 seconds then back on, then do the factory reset and setup from scratch.
        Don't worry about the suggestions for wireless I meantioned. That would be if the console was wireless connected.
        If after doing the reset and setup from scratch doesn't solve this, I would revert back to prior working FW version.
        See reply here:
        https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/does-anyone-no-what-this-means/td-p/1689970/jump-to/first-unread-message
  • FURRYe38's avatar
    When you do a reset and setup from scratch, I would also change the default LAN IP address pool to 192.168.1 100 to .150 or .200.
    Then set up IP address reservations for your devices and the xbox.
    I would also do a hard reset on the game console as well. Hold the power button on the front untill it shuts off. Do a IP address reservation on the router, save changes then reboot. Then power ON the xbox.
    • Rick6922's avatar
      Rick6922
      Luminary
      OMG, did a factory reset and router wouldnt let me back in. finily got in but i had already set ip last # to 250. already did those things, look at the system log........................6 [DumaOS] Marking device that is marked 192.168.1.6 5 2., Sunday, January 13, 2019 17:41:20 [Internet connected] IP address: 24.95.165.47, Sunday, January 13, 2019 17:40:40 [Internet disconnected] Sunday, January 13, 2019 17:40:38 [DumaOS] Marking device that is marked 192.168.1.6 5 2., Sunday, January 13, 2019 17:39:21 [Internet connected] IP address: 24.95.165.47, Sunday, January 13, 2019 17:38:40 [DumaOS] Marking device that is marked 192.
  • Firmware 1.0.1.2 and 1.0.1.8 are not stable.  WAN/Internet drops are prominent.  Only workaround that I have found is to just downgrade to 1.0.0.20.  It is a stable firmware version.
  • i fiqured it out, thanks to all that responed!
  • FURRYe38's avatar
    So was the fix? Please let us know so other will know.
