cerjzc
May 19, 2017Tutor
Pro 6 won't boot up after going from 6.7.1 to 6.7.3
Upgraded my pro 2 from 6.7.1 to 6.7.3 beta without any issues, but tried my Pro 6 a bit later and it appears to have not gone well. It showed upgrading FW on the screen for a long time and from the ...
- May 19, 2017
Yes you had the same problem. It should now be fixed.
Edit:
If you have updated to 6.7.3 and ran into this issue please try USB Boot Recovery (note for those using RAIDiator-x86 systems such as the Pro 6 you'll need to use the RAIDiator-x86 4.2.x USB Boot Recovery tool with the OS6 firmware renamed to RAIDiator-x86-something) with ReadyNAS OS 6.7.4 which is now available!
If you have not yet upgraded please upgrade to 6.7.4 rather than 6.7.3. If your system has already been fixed I would still suggest updating to 6.7.4 the normal way using the web admin GUI.
cerjzc
May 19, 2017Tutor
After a bit more digging via ssh I think I might be having the same problem as noted here:
Filesystem 1K-blocks Used Available Use% Mounted on
udev 10240 4 10236 1% /dev
/dev/md0 4190208 1144380 0 100% /
tmpfs 2018872 8 2018864 1% /dev/shm
tmpfs 2018872 16964 2001908 1% /run
tmpfs 1009436 8 1009428 1% /run/lock
tmpfs 2018872 0 2018872 0% /sys/fs/cgroup
/dev/md126 11696688832 5317807976 6377199192 46% /data
/dev/md126 11696688832 5317807976 6377199192 46% /apps
/dev/md126 11696688832 5317807976 6377199192 46% /home
root@CalvCoNAS:/mnt/var/cores# btrfs fi df /
Data, single: total=3.57GiB, used=580.03MiB
System, DUP: total=8.00MiB, used=16.00KiB
System, single: total=4.00MiB, used=0.00B
Metadata, DUP: total=204.56MiB, used=12.75MiB
Metadata, single: total=8.00MiB, used=0.00B
GlobalReserve, single: total=512.00MiB, used=320.25MiB
root@CalvCoNAS:/mnt/var/cores# btrfs fi usage /
Overall:
Device size: 4.00GiB
Device allocated: 4.00GiB
Device unallocated: 0.00B
Device missing: 0.00B
Used: 605.56MiB
Free (estimated): 3.00GiB (min: 3.00GiB)
Data ratio: 1.00
Metadata ratio: 1.96
Global reserve: 512.00MiB (used: 320.25MiB)
Data,single: Size:3.57GiB, Used:580.03MiB
/dev/md0 3.57GiB
Metadata,single: Size:8.00MiB, Used:0.00B
/dev/md0 8.00MiB
Metadata,DUP: Size:204.56MiB, Used:12.75MiB
/dev/md0 409.12MiB
System,single: Size:4.00MiB, Used:0.00B
/dev/md0 4.00MiB
System,DUP: Size:8.00MiB, Used:16.00KiB
/dev/md0 16.00MiB
Unallocated:
/dev/md0 0.00B
I found there was a /var/cores/core-smdb file, but I'm unable to move or remove anything as I just get the message "No space left on device". The other post mentions that Skywalker was able to fix the root fs, but it doesn't mention what was done.
I did also try to download the logs, but it failes most likely because of the space issue as well.
Thanks,
Jeff
mdgm-ntgr
May 19, 2017NETGEAR Employee Retired
I see what Skywalker did. I've replied to your PM.
- mdgm-ntgrMay 19, 2017NETGEAR Employee Retired
Edit:
