cerjzc
May 19, 2017Tutor
Pro 6 won't boot up after going from 6.7.1 to 6.7.3
Upgraded my pro 2 from 6.7.1 to 6.7.3 beta without any issues, but tried my Pro 6 a bit later and it appears to have not gone well. It showed upgrading FW on the screen for a long time and from the ...
- May 19, 2017
Yes you had the same problem. It should now be fixed.
Edit:
If you have updated to 6.7.3 and ran into this issue please try USB Boot Recovery (note for those using RAIDiator-x86 systems such as the Pro 6 you'll need to use the RAIDiator-x86 4.2.x USB Boot Recovery tool with the OS6 firmware renamed to RAIDiator-x86-something) with ReadyNAS OS 6.7.4 which is now available!
If you have not yet upgraded please upgrade to 6.7.4 rather than 6.7.3. If your system has already been fixed I would still suggest updating to 6.7.4 the normal way using the web admin GUI.
mdgm-ntgr
May 19, 2017NETGEAR Employee Retired
I see what Skywalker did. I've replied to your PM.
mdgm-ntgr
Edit:
- buddy81May 25, 2017Aspirant
I have the same problem...need help...what can i do?
