cerjzc
May 19, 2017Tutor
Pro 6 won't boot up after going from 6.7.1 to 6.7.3
Upgraded my pro 2 from 6.7.1 to 6.7.3 beta without any issues, but tried my Pro 6 a bit later and it appears to have not gone well. It showed upgrading FW on the screen for a long time and from the ...
- May 19, 2017
Yes you had the same problem. It should now be fixed.
Edit:
If you have updated to 6.7.3 and ran into this issue please try USB Boot Recovery (note for those using RAIDiator-x86 systems such as the Pro 6 you'll need to use the RAIDiator-x86 4.2.x USB Boot Recovery tool with the OS6 firmware renamed to RAIDiator-x86-something) with ReadyNAS OS 6.7.4 which is now available!
If you have not yet upgraded please upgrade to 6.7.4 rather than 6.7.3. If your system has already been fixed I would still suggest updating to 6.7.4 the normal way using the web admin GUI.
goi
May 25, 2017Guide
sure:
First of all:
DISCLAIMER: Commands given here are for tutorial reasons only - i give neither an implied nor expressive warranty that these commands will work as intended.
MORE OVER A WARNING: They might destroy the integrity of your data and you are obliged to make a backup before!
At first determine of which drives your md0 device is made of:
# mdadm --detail /dev/md0
/dev/md0:
Version : 1.2
Creation Time : Mon Apr 18 22:58:10 2016
Raid Level : raid1
Array Size : 4190208 (4.00 GiB 4.29 GB)
Used Dev Size : 4190208 (4.00 GiB 4.29 GB)
Raid Devices : 6
Total Devices : 6
Persistence : Superblock is persistent
Update Time : Thu May 25 18:00:01 2017
State : clean
Active Devices : 6
Working Devices : 6
Failed Devices : 0
Spare Devices : 0
Name : 540ed549:0 (local to host 540ed549)
UUID : 3201e354:b9fcd222:f4d2fe4d:888dc6f6
Events : 19025
Number Major Minor RaidDevice State
11 8 1 0 active sync /dev/sda1
10 8 17 1 active sync /dev/sdb1
5 8 33 2 active sync /dev/sdc1
4 8 49 3 active sync /dev/sdd1
3 8 81 4 active sync /dev/sde1
6 8 97 5 active sync /dev/sdf1
assure that the drive is clean and no extensive i/o is on this drive. Warning: If the drives are in another enumaration (e.g. sda, sdb, sdc, sdd, sdf, sdg) you need to adapt the commands to the changed drive letters.
Now mark the 4 drives you don't need yet as "failed"
# mdadm /dev/md0 --manage --fail /dev/sdf1
# mdadm /dev/md0 --manage --fail /dev/sde1
# mdadm /dev/md0 --manage --fail /dev/sdd1
# mdadm /dev/md0 --manage --fail /dev/sdc1
You can now savely tell the raid manager that those 4 drives aren't necessary any more and not part of this array anymore:
# mdadm --grow --backup-file=/data/md0backup/tmpfile --raid-devices=2 /dev/md0
Now we remove and add 3 drives to mark them as "spares" and remove the last drive only, because we migrate from RAID1 to RAID5 and afterwards to RAID6.
# mdadm /dev/md0 --manage --remove /dev/sdc1 --add /dev/sdc1
# mdadm /dev/md0 --manage --remove /dev/sdd1 --add /dev/sdd1
# mdadm /dev/md0 --manage --remove /dev/sde1 --add /dev/sde1
# mdadm /dev/md0 --manage --remove /dev/sdg1
now we are ready to rumble: Please give a backup file for this operation in case anything goes wrong during the very first part of the migration:
We are now migrating a two disk RAID1 into a 2 disk RAID5 (yes it works this way with mdadm!)
# mdadm --grow --backup-file=/data/md0backup/tmpfile --level=5 /dev/md0
and wait until the raid system resynched and shows "clean" :
/dev/md0:
Version : 1.2
Raid Level : raid5
Raid Devices : 2
Total Devices : 5
State : clean
Active Devices : 2
Working Devices : 2
Failed Devices : 0
Spare Devices : 0
Layout : left-symmetric
Chunk Size : 64K
Events : 19025
You'll get a warning that some data had to be stored into the given backup file!
Now we extend our RAID5 with the 3 additional spares:
# mdadm --grow --backup-file=/data/md0backup/tmpfile --raid-devices=5 /dev/md0
please wait until the synchronization succeeds:
/dev/md0:
Version : 1.2
Raid Level : raid5
Array Size : 16760832 (15.98 GiB 17.16 GB)
Raid Devices : 5
Total Devices : 5
State : clean
Active Devices : 5
Working Devices : 5
Failed Devices : 0
Spare Devices : 0
Chunk Size : 64K
Events : 19025
Now we add the last spare to it and make it RAID6:
# mdadm /dev/md0 --manage --add /dev/sdf1
# mdadm --grow --backup-file=/data/md0backup/tmpfile --level=6 /dev/md0
Side note: the raid grow to level 6 will automatically adjust the raid-devices parameter to 6.
Again please wait until the raid is synchronized and the new layout ist cleanly available:
/dev/md0:
Version : 1.2
Raid Level : raid6
Raid Devices : 6
Total Devices : 6
State : clean
Active Devices : 6
Working Devices : 6
Failed Devices : 0
Spare Devices : 0
Chunk Size : 64K
Events : 19025
The last step is to tell the filesystem it has now a different size:
# btrfs filesystem resize max /
check if it is applied:
# df -h
Filesystem Size Used Avail Use% Mounted on
udev 10M 4.0K 10M 1% /dev
/dev/md0 16G 1.2G 15G 8% /
tmpfs 3.9G 0 3.9G 0% /dev/shm
tmpfs 3.9G 2.6M 3.9G 1% /run
tmpfs 2.0G 1.1M 2.0G 1% /run/lock
tmpfs 3.9G 0 3.9G 0% /sys/fs/cgroup
/dev/md127 19T 5.2T 14T 28% /data
/dev/md127 19T 5.2T 14T 28% /home
/dev/md127 19T 5.2T 14T 28% /apps
You are now set!
mdgm-ntgr
May 27, 2017NETGEAR Employee Retired
