MaxxMark's avatar
MaxxMark
Luminary
Aug 12, 2016
Pro Pioneer - Poor performance X-RAID Raid-6 with 6x WD Red 3TB
For a really long time I thought the poor performance was due to the fact that I was running an old firmware and had never done a factory reset since 2009 (it was recommended in the past on the forum...
  • MaxxMark's avatar
    MaxxMark
    Aug 15, 2016
    For future readers;
    The performance impact boiled down to the following things:
    1. The RAID implementation currently works different in comparison to older versions of the NAS which has impact on performance, but delivers more reliability
    2. The implementation of NFS (and/or NFSv4) works different and by default works in a more reliable way. Using the "async" option will greatly improve the speed of transfers, but will greatly increase the risk of faulty transfers in case of power-failure and such
    3. Performance is (obviously) impacted when there are operations running (ie: (initial) (re)syncing of volumes, balancing, scrubbing, defragmentation, simultanious transfers, etc.)
    I tested diskspeeds within my system to evaluate the performance impact. My conclusion for now is that in a RAID-5 or RAID-6 setup the set won't perform better than an individual disk (which was the case in older versions of ReadyNAS but seems to not be true anymore, probably due to the first point). When using the async option, the performance is equal to the individual disks.  Note; I have *not* compared speeds using CIFS/Samba. I have tested one time and it seemed that the speeds were comparable to NFS with the async option turned on.
ProSupport for Business
