victorhortalive
Oct 20, 2010Aspirant
Pro Pioneer - Spin Down working or not ?
I can't seem to get any response from my Pro Pioneer on Spin Down. Either it's working and doesn't want to tell me OR it's not working ! I have 4 Seagate 2TB ST32000542AS drives with a 60min spin ...
mdgm-ntgr
Oct 20, 2010NETGEAR Employee Retired
I'll try to use disk spin-down tonight on the Ultra 6 (different to the Pro, I know, but I don't have a Pro - hopefully someone with a Pro can check on that as that would be better). I haven't tried it for a while but it did work for me using older firmware. I'll try with 4.2.15.
You don't use your Pro as a WINS server do you? If the disks are being used (for whatever reason) the NAS won't spin down.
