victorhortalive
Oct 20, 2010Aspirant
Pro Pioneer - Spin Down working or not ?
I can't seem to get any response from my Pro Pioneer on Spin Down. Either it's working and doesn't want to tell me OR it's not working ! I have 4 Seagate 2TB ST32000542AS drives with a 60min spin ...
mdgm-ntgr
Oct 22, 2010NETGEAR Employee Retired
You might want to contact tech support for advice and post your case number. They would likely know a list of common problems that can cause disk spin-down to stop working.
Do you use iSCSI?
Do you use iSCSI?
