victorhortalive
Oct 20, 2010Aspirant
Pro Pioneer - Spin Down working or not ?
I can't seem to get any response from my Pro Pioneer on Spin Down. Either it's working and doesn't want to tell me OR it's not working ! I have 4 Seagate 2TB ST32000542AS drives with a 60min spin ...
victorhortalive
Oct 26, 2010Aspirant
The second Pro Pioneer now has 2x Samsung 1.5TB drives in it and seems to be behaving properly wrt spindown !
Here's an extract from the logs and you can see that it's doing a whole lot of stuff between spindown (top) and spinup (bottom).
(Including mounting a SCSI drive - which I don't have enabled !)
I caused the spinup by adding a 3rd 1.5TB drive.
Maybe spindown doesn't like the Seagate 2TB 5900rpm drives.
Oct 26 19:25:38 nas-EA-75-45 noflushd[1663]: Spinning down disks.
Oct 26 22:03:47 nas-EA-75-45 kernel: ata4: exception Emask 0x10 SAct 0x0 SErr 0x4050000 action 0xe frozen
Oct 26 22:03:47 nas-EA-75-45 kernel: ata4: irq_stat 0x00400040, connection status changed
Oct 26 22:03:47 nas-EA-75-45 kernel: ata4: SError: { PHYRdyChg CommWake DevExch }
Oct 26 22:03:47 nas-EA-75-45 kernel: ata4: hard resetting link
Oct 26 22:03:53 nas-EA-75-45 kernel: ata4: link is slow to respond, please be patient (ready=0)
Oct 26 22:03:57 nas-EA-75-45 kernel: ata4: COMRESET failed (errno=-16)
Oct 26 22:03:57 nas-EA-75-45 kernel: ata4: hard resetting link
Oct 26 22:03:59 nas-EA-75-45 kernel: ata4: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
Oct 26 22:03:59 nas-EA-75-45 kernel: ata4.00: ATA-8: ST31500341AS, CC1H, max UDMA/133
Oct 26 22:03:59 nas-EA-75-45 kernel: ata4.00: 2930277168 sectors, multi 0: LBA48 NCQ (depth 31/32)
Oct 26 22:03:59 nas-EA-75-45 kernel: ata4.00: configured for UDMA/133
Oct 26 22:03:59 nas-EA-75-45 kernel: ata4: EH complete
Oct 26 22:03:59 nas-EA-75-45 kernel: scsi 3:0:0:0: Direct-Access ATA ST31500341AS CC1H PQ: 0 ANSI: 5
Oct 26 22:03:59 nas-EA-75-45 kernel: sd 3:0:0:0: [sdc] 2930277168 512-byte logical blocks: (1.50 TB/1.36 TiB)
Oct 26 22:03:59 nas-EA-75-45 kernel: sd 3:0:0:0: [sdc] Write Protect is off
Oct 26 22:03:59 nas-EA-75-45 kernel: sd 3:0:0:0: [sdc] Mode Sense: 00 3a 00 00
Oct 26 22:03:59 nas-EA-75-45 kernel: sd 3:0:0:0: [sdc] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
Oct 26 22:03:59 nas-EA-75-45 kernel: sdc:
Oct 26 22:03:59 nas-EA-75-45 kernel: sd 3:0:0:0: Attached scsi generic sg2 type 0
Oct 26 22:03:59 nas-EA-75-45 kernel: sdc1
Oct 26 22:03:59 nas-EA-75-45 kernel: sd 3:0:0:0: [sdc] Attached SCSI disk
Oct 26 22:04:08 nas-EA-75-45 noflushd[1663]: Disks spinning up after 158 minutes.
