victorhortalive
Oct 20, 2010Aspirant
Pro Pioneer - Spin Down working or not ?
I can't seem to get any response from my Pro Pioneer on Spin Down. Either it's working and doesn't want to tell me OR it's not working ! I have 4 Seagate 2TB ST32000542AS drives with a 60min spin ...
alldidasmc
Sep 09, 2011Aspirant
dandan,
You've checked the LOGs and you're sure your HD's are not spinning up? Check the System log. Close examination of the LOG files usually reveals that the drives are constantly being spun-up for no reason, so you should be sure if you don't want your drives destroyed!
-Robert
-Robert
