FlaviaS
Jul 12, 2022Star
Pro6 DiskTrays with round button
I have a Pro6 and several Ultra2, all bought second hand. Pro6 came with older model disktrays which have a round button which needs to be pressed to make the handle pop-up. Ultra2's cam with disk tr...
Sandshark
Jul 13, 2022Sensei
It'
s flat-out a bad design, which is why it was replaced. Forget the buttons and use a small screwdriver or bent paper clip to release the trays. Here's a video somebody made: https://www.youtube.com/watch?v=zKczCPiqc-4 .
FlaviaS
Jul 13, 2022Star
Wow, thank you, I was sure there are many people having the same issue and somebody should have found a workaround. I also mucked around with the paperclip and the hole in the middle of the button with no results like the person in the video but the hole next to the blocked hole worked like a charm.
