FlaviaS
Nov 18, 2025Star
Pro6 reduction of power consumption
I have several Netgear Pro6 systems. They were upgraded to RaidOS 6.10, Intel E7600 CPUs and 4GB ram and are working great (had to recap the Seasonic power supplies since the caps were bulging). I al...
FlaviaS
Nov 18, 2025Star
Hi Stephen,
Yes, the fans are spinning hard, at full speed I think, although I took care to also upgrade the BIOS of the Pro6 before upgrading to RaidOS 6 (I know older BIOS was known to cause this). The temps are also low (36 degree Celsius system and 40 degree Celsius CPU which do not seem to justify the fan speeds. Even with the NAS powered off it still uses 4.5Watt while the Ultra 6 with identical power supply but different motherboard uses 1.5 watt when off. The amount of data I have makes impractical to switch to NVME at the moment, I have 24 drives of 3TB each Raid 1+0 distributed over 5 NASes (4 Pro6, 1 Ultra6). I would rather try to buy some larger capacity drives (18TB, Helium based Ultrastars), consolidate the smaller drives and retire some of the Pro6 systems but budget is tight. At least spinning down the drives when not in use works fine.
Nov 19, 2025Guru - Experienced User
FlaviaS wrote:The temps are also low (36 degree Celsius system and 40 degree Celsius CPU which do not seem to justify the fan speeds.
The system boots from the disks, so when powering up diskless the system is running the boot loader in the flash. That loader has no thermal management, so the fans run at full speed.
FlaviaS wrote:Even with the NAS powered off it still uses 4.5Watt while the Ultra 6 with identical power supply but different motherboard uses 1.5 watt when off.
Not particularly surprising, since the Pro-6 -100NAS was launched in 2008, and the Ultra 6 was launched in 2011.
FlaviaS wrote:I have 24 drives of 3TB each Raid 1+0 distributed over 5 NASes (4 Pro6, 1 Ultra6).
So about 36 TB total capacity? Are some of these NAS used for backup?
Fewer larger disks certainly makes sense to me. You can phase this in over time (purchasing in pairs), you don't need to purchase all at once.
In the short term, you'd be able to retire some NAS now if you switched to X-RAID/RAID-5. Three 6x3TB arrays would give you 45 TB of storage.
