itachi2
Feb 01, 2019Tutor
PRO6 "Remove inactive volumes" after interrupted balance
Firmware 6.9.3, RAID 6, 6 drives. I let the volume get really full before my autoscheduled balance kicked on and ground everything to a halt. Forced reboot gives all red drives and the "Remove inac...
- Feb 05, 2019
Hi itachi2,
It appears that the volume is already filled up when the balance ran which has given it no room to rewrite the data. When the file system comes up, it is trying to finish a large amount of previous tasks but there is no space so it just locks up.
You can try booting the NAS to read-only and check if you can access the data that way. Otherwise you have to look for the 3rd party data recovery to assist you in recovering the data.
As what StephenB mentioned, Pro 6 with OS6 firmware is not supported by NETGEAR.
JohnCM_S
Feb 05, 2019NETGEAR Employee Retired
Hi itachi2,
