highintensity
Dec 18, 2014Tutor
Pro6 Upgraded from OS6.X to 6.2 Lost Raidar Access
Hi, I had my readynas Pro6 with 6 3TB drives running perfectly with OS6.X from the start, it was actually a breeze. Then I upgraded it to OS6.2 without a problem and it ran for a month perfectly. I h...
RX
Dec 18, 2014Luminary
Since you are able to access the shares but cannot get the data, have you tried connecting a PC directly to your ReadyNAS Pro6 and check if you are able to access and get your data stored in it?
