arovik
Apr 22, 2014Aspirant
Problem after doing os reinstall
Hi. I did a OS Reinstall on my 314 to manage to get into the frontview, because it did not work. What happened when i used the os reinstall is that it came up with this error message "err: disk cont...
Marto731
Arovik,
The problem is what happened to crash Frontview before the OS Reinstall.
Did you add disks that
(a) were formatted on a different NAS, with a different OS?
(b) had data on it.?
Support, if they get SSH, access may advise removing a disk, and reboot.
Regards, Marto
Regards, Marto
- Jul 15, 2018Retired_Member
