cat71
Sep 06, 2017Aspirant
problem changing IP
i used 10.1.2.10 as IP for nic eth0. eth1 has IP 192.168.178.10
now i conect to 192.168.178.10
unter network i want to change ip 10.1.2.10 to 10.1.1.10.
ip 10.1.1.10
subnet 255.255.255.0
route 10.1.1.1
dns 10.1.1.1
the ip do not change after pressing ok. the IP is still 10.1.2.1. , try some times.
witout dns or and route
the eth1 is configured as:
ip 192.168.178.2
netmask 255.255.255.0
droute 192.168.178.1
dns 192.169.178.1
i can change the IP of eth1.
Any ideas ?
posible to change the ip in cli ?
nothing in /etc/netowork/interface, where is the place vor conf?
- Marty_MNETGEAR Employee Retired
Hello cat71,
It does appear that you are trying to set eth1 to static ip address but it is not updating. Please try using different browser and computer in setting up the ip address from the admin page. You may also try to disconnecting first eth 0 then change the setting of eth 1. Please check if you can change other setting on the NAS, like if you could enable or disable services. There is a possibility that OS partition is filling up, that is the reason why any changes made are not updating.
Marty_M
NETGEAR Community Team- cat71Aspirant
Hello,
Firmware 6.8.0.
I check it from different Computers, with sometimes IE or Chrome (Ubuntu, WIndows 10).
I try direkt connect to a switch with only one line and only one pc on an other port. (only eth0, only eth2, both)
i try eth1 dhcp enabled.(connect to router (dhcpd) , and its possible to change the adress auf eth1).
i change eth1 to the same subnet, and same IP from the the last setting bevore i change the IP of eth0,
nothing helps.
i have no problems to change other setting .
is there a possibility to change the ip in a config file ?
space of nas:
df
Filesystem 1K-blocks Used Available Use% Mounted on
udev 10240 4 10236 1% /dev
/dev/md0 3862208 1192356 2443960 33% /
tmpfs 254200 0 254200 0% /dev/shm
tmpfs 254200 472 253728 1% /run
tmpfs 127104 7492 119612 6% /run/lock
tmpfs 254200 0 254200 0% /sys/fs/cgroup
/dev/md127 8776244352 7556139084 1218066804 87% /data.....
df -i
Filesystem Inodes IUsed IFree IUse% Mounted on
udev 63109 441 62668 1% /dev
/dev/md0 1048576 43645 1004931 5% /
tmpfs 63550 1 63549 1% /dev/shm
tmpfs 63550 599 62951 1% /run
tmpfs 63550 28 63522 1% /run/lock
tmpfs 63550 9 63541 1% /sys/fs/cgroup
/dev/md127 0 0 0 - /data- Marty_MNETGEAR Employee Retired
Hello cat71,
It does appear the OS partition is in a good condition. Changing the ip address from the config file will require backend access to the NAS if you are well versed with linux I believe that will work. I would recommend to perform an OS re-install, part of the process will reset the network setting of the NAS.
Marty_M
