fastfwd
Jan 15, 2017Virtuoso
Problem getting Intel microcode to load early on my Frankenstein NAS
So... After running multiple legacy ReadyNAS boxes on OS4 for 5+ years, I've decided to upgrade to OS6. I wish I knew who made the decision to include software support for legacy devices in OS6 (and...
- Jan 17, 2017
Ok, I've answered my own question. It is NOT necessary to lzma-compress the initramfs file on the boot flash.
As described in my previous post, I created a cpio archive just like the one inside initrd.gz, except that it also contains the /kernel/x86/microcode/GenuineIntel.bin file with my CPU's microcode update. Copied it to the boot flash without lzma-compressing it first (called it "initrduc"), edited SYSLINUX.CFG to load it along with my new kernel ("k4-1-30.uc") as a boot-menu option, and boom:
root@NAS3:~# dmesg | head [ 0.000000] microcode: CPU0 microcode updated early to revision 0xd0, date = 2010-09-30 [ 0.000000] Initializing cgroup subsys cpuset [ 0.000000] Initializing cgroup subsys cpu [ 0.000000] Initializing cgroup subsys cpuacct [ 0.000000] Linux version 4.1.30.x86_64.1 (root@NAS3) (gcc version 4.9.2 (Debian 4.9.2-10) ) #2 SMP Tue Jan 17 01:33:26 PST 2017 [ 0.000000] Command line: initrd=initrduc reason=normal BOOT_IMAGE=k4-1-30.uc [ 0.000000] KERNEL supported cpus: [ 0.000000] Intel GenuineIntel [ 0.000000] Disabled fast string operations [ 0.000000] e820: BIOS-provided physical RAM map:
Now my NAS not only has a CPU updated to the latest microcode, it's also running a kernel built specifically for its hardware (Core2 Duo CPU, Yukon2 Ethernet chip) and with a few other optimizations for that hardware.
If everything's still running fine a few days from now, I'll make this kernel/initramfs combo the default, and make the original combo a boot-menu option. Then I'll run through the process again for my main NAS, and maybe also for the Atom D525 in my little Ultra 2 Plus.
mdgm-ntgr
Jan 16, 2017NETGEAR Employee Retired
1. Modifying that would require building your own /init for it as well, I think
2. I think it would be unlikely that that would happen. The number of users that would benefit would be quite small. Unsupported unit for OS6 with an unsupported CPU upgrade
fastfwd
Jan 16, 2017Virtuoso
Thanks, mdgm.
Your comment helped me to find what I think is a way to do what I want, and it's actually super-easy. I'll try it after lunch and post an update here.
And, yeah, I agree that it's unlikely that OS6 will include kernel features not only for products no longer supported by Netgear, but also for products that were NEVER supported by Netgear... But I made the suggestion anyway, under the basic principle of "It can't hurt to ask".
