acepilot1023
Oct 03, 2012Aspirant
Problem installing second disk in RAID0
Okay, so for a little while now I've had a second 1TB drive ready to accompany my 2TB drive in my ReadyNAS Duo V2. When I placed the drive in, it showed up in RAIDar in the green LED. However, when I ...
chirpa
Oct 07, 2012Luminary
That would be considered JBOD, not RAID-0, since the drive capacity doesn't match.
If you replaced the Disk1 1TB with a 2TB, the volume would expand to 2TB usable.
The default setup for Duo v2 is X-RAID2, which can only be one volume. To use the extra 1TB of space on that second disk, you would have to factory default (erase all data) and switch to Flex-RAID mode.
