arran1
May 25, 2013Aspirant
Problem installing wit RAIDar
Hello, I just bought a a ReadyNAS RN102 with two disks but I'm having problem getting started. The disks I bought are two 1TB Western Digital GREEN drives. I realized later that these drives are...
arran1
May 26, 2013Aspirant
Trying doing a factory default according to the manual. Not sure if it did anything though.
I can access the boot menu, and then cycle through the options with the reset-button. But when I choose the factory default option the power light will light up for a few seconds but then it will revert to just blinking as before.
RAIDar will still find the unit, but is still reporting missing disks.
Didn't get a manual when I bought the nas, but I did get a little note in the package that says I should go to http://readycloud.netgear.com to install the device. However, it says it cannot find any devices there.
