loddar61
Oct 11, 2011Aspirant
Problem with access via CIFS, NFS works fine
Hello perhaps someone is so kind to help me with a problem which really makes me mad: I've got a ReadyNAS Ultra 2, some weeks ago I resetted the Ultra to factory default while installing 2 2TB HDs. ...
sphardy1
Oct 11, 2011Apprentice
You just confirmed the issue is the one I referred to - usually you can rename the share back to media and the config is fixed. Don't know why not in your case. Please log in the beta forum as 4.2.20 should fix that issue and clearly it has not
