danieleb001's avatar
danieleb001
Problem with an old Readynas2000
Hello everybody, This week my Readynas2000 notified me problems with power supply. messages I got were relòated to poversupply between 10,5V instead of 12V. I tried to fix it replacing the external...
  • Sandshark's avatar
    Sandshark
    Nov 28, 2017
    If you decide to get a used replacement, make sure you do get a compatible one.  You said you have a "ReadyNAS 2000", but there are a lot of models that have a 2000 number.  There is the original Duo (RND2000-100), the Pro2 (RNDP2000-100), Ultra2 (RNDU2000-100), and Duo V2 (RND2000-200).  Only the Pro2 and Ultra2 are compatible with each other.  And if you have a Duo, Netgear used "V2" in two different ways.  Most of the "V2" systems I see for sale on eBay are really V1's.  The best way to tell these all apart from a listing is to look at the back.  Fan size and number of ethernet ports are what to look for.  Duo V1, small fan (also recessed power jack).  Duo V2, large fan and one network port.  Pro2 and Ultra2, large fan and two network ports.  Of course, you could also upgrade to a compatible unit with more bays (where the list gets even more complicated)
ProSupport for Business
