trumpy81
Feb 02, 2015Aspirant
Problem with NV+ (v1)
I have an issue with my NV+, It seems that something has gone wrong with RAIDiator 4.1.14 and I am unable to access the ReadyNAS via CIFS, the NV+ wont accept the connection according to Windows. F...
mdgm-ntgr
Feb 02, 2015NETGEAR Employee Retired
When you do a factory default a sync is required, to sync the disks sector by sector to setup the RAID. It is normal when all four slots are filled for the Disk 4 light to be blinking during this sync.
Under Volumes do you see a sync in progress?
