Cameleon1950's avatar
Feb 01, 2016
Problem with RAIDar 6.1 and Windows 10
I've got myself a new PC with Windows 10 I have installed te Raidar 6.1 version. When i start it, it finds the Netgear ReadyNas duo v2. It reports correct the drives in it and the IP address of the...
  • StephenB's avatar
    Feb 02, 2016
    RAIDar 6.1 is the latest version - but Netgear is more focused on OS6 NAS than older end-of-life NAS.   There are some issues with RAIDar 6.x and the legacy NAS.
    The simplest answer is to use RAIDar 4.3.8 with your older NAS.
    Cameleon1950 wrote:
    When i check the label on the bottom of the ReadyNas, it tells me :  Readynas Duo RND2000 V2
    I know.  But it still is a duo v1.  Ready the link I posted, it explains the labeling.  Calling it a v2 can result in getting wrong advice here.
ProSupport for Business
