Cameleon1950
Feb 01, 2016Tutor
Problem with RAIDar 6.1 and Windows 10
I've got myself a new PC with Windows 10 I have installed te Raidar 6.1 version. When i start it, it finds the Netgear ReadyNas duo v2. It reports correct the drives in it and the IP address of the...
- Feb 02, 2016
RAIDar 6.1 is the latest version - but Netgear is more focused on OS6 NAS than older end-of-life NAS. There are some issues with RAIDar 6.x and the legacy NAS.
The simplest answer is to use RAIDar 4.3.8 with your older NAS.
Cameleon1950 wrote:
When i check the label on the bottom of the ReadyNas, it tells me : Readynas Duo RND2000 V2
I know. But it still is a duo v1. Ready the link I posted, it explains the labeling. Calling it a v2 can result in getting wrong advice here.
Feb 01, 2016Guru - Experienced User
It reports correct the drives in it and the IP address of the NAS. and the firmwareversion of the NAS, 4.1.14
You have a duo v1 (duo v2 runs 5.3.x firmware). The label is confusing - see this for more details: http://www.rnasguide.com/2012/01/09/how-to-tell-whether-i-have-a-duo-v1-or-duo-v2-or-nv-v1-or-nv-v2/
But, When i try to go to the management environment, i've got an Error, saying that there is no access to the NAS ??
What happens if you open your web browser, and enter
https://ipaddress-of-nas/admin
Cameleon1950
Feb 02, 2016Tutor
Last week i upgraded the firmware to version 4.1.14 becuase of the problems i run in the afther
i connect this Nas with my new PC
If i access the management environmet manual bij put in HTTPS:// < Ip address>>/admin in the browser
ik works normaly and when i accept the message, sayintg the the certificate is not valid, i can log in
and access the management environment.
In the meantime i've download the old version of RAIDar, 4.3.8 and that works normally ???
But when i seurch the support site of Netgear it tells me that version 6.1 is the last version ?
See also the message below
- Cameleon1950Feb 02, 2016Tutor
as requested some pictures o
RAIDar screen afther using the tool
reporting the right NAS, firmware version, drives and IP address
Error message in Dutch, telling me that there is no Network access ?
sorry, screenshot of the RAIDar program was before i upgraded the firmware to version 4.1.14
Cor
- StephenBFeb 02, 2016Guru - Experienced User
