Cameleon1950
Feb 01, 2016Tutor
Problem with RAIDar 6.1 and Windows 10
I've got myself a new PC with Windows 10 I have installed te Raidar 6.1 version. When i start it, it finds the Netgear ReadyNas duo v2. It reports correct the drives in it and the IP address of the...
- Feb 02, 2016
RAIDar 6.1 is the latest version - but Netgear is more focused on OS6 NAS than older end-of-life NAS. There are some issues with RAIDar 6.x and the legacy NAS.
The simplest answer is to use RAIDar 4.3.8 with your older NAS.
Cameleon1950 wrote:
When i check the label on the bottom of the ReadyNas, it tells me : Readynas Duo RND2000 V2
I know. But it still is a duo v1. Ready the link I posted, it explains the labeling. Calling it a v2 can result in getting wrong advice here.
Cameleon1950
Feb 02, 2016Tutor
Last week i upgraded the firmware to version 4.1.14 becuase of the problems i run in the afther
i connect this Nas with my new PC
If i access the management environmet manual bij put in HTTPS:// < Ip address>>/admin in the browser
ik works normaly and when i accept the message, sayintg the the certificate is not valid, i can log in
and access the management environment.
In the meantime i've download the old version of RAIDar, 4.3.8 and that works normally ???
But when i seurch the support site of Netgear it tells me that version 6.1 is the last version ?
See also the message below
Cameleon1950
Feb 02, 2016Tutor
as requested some pictures o
RAIDar screen afther using the tool
reporting the right NAS, firmware version, drives and IP address
Error message in Dutch, telling me that there is no Network access ?
- Cameleon1950Feb 02, 2016Tutor
sorry, screenshot of the RAIDar program was before i upgraded the firmware to version 4.1.14
Cor
- StephenBFeb 02, 2016Guru - Experienced User
- kohdeeFeb 02, 2016Administrator
The only issue with RAIDar 6 and RAIDiator 4.1 is that some earlier versions of RAIDiator 4.1 (4.1.0-4.1.3) use an extremely old protocol; for those versions, you would want to use RAIDar 4. RAIDiator 4.1.3+, RAIDiator 4.2, RAIDiator 5.3, and ReadyNAS OS 6 should all work with RAIDar 6.
