Cameleon1950
Feb 01, 2016Tutor
Problem with RAIDar 6.1 and Windows 10
I've got myself a new PC with Windows 10 I have installed te Raidar 6.1 version. When i start it, it finds the Netgear ReadyNas duo v2. It reports correct the drives in it and the IP address of the...
- Feb 02, 2016
RAIDar 6.1 is the latest version - but Netgear is more focused on OS6 NAS than older end-of-life NAS. There are some issues with RAIDar 6.x and the legacy NAS.
The simplest answer is to use RAIDar 4.3.8 with your older NAS.
Cameleon1950 wrote:
When i check the label on the bottom of the ReadyNas, it tells me : Readynas Duo RND2000 V2
I know. But it still is a duo v1. Ready the link I posted, it explains the labeling. Calling it a v2 can result in getting wrong advice here.
Feb 02, 2016Guru - Experienced User
kohdee
Feb 02, 2016NETGEAR Expert
The only issue with RAIDar 6 and RAIDiator 4.1 is that some earlier versions of RAIDiator 4.1 (4.1.0-4.1.3) use an extremely old protocol; for those versions, you would want to use RAIDar 4. RAIDiator 4.1.3+, RAIDiator 4.2, RAIDiator 5.3, and ReadyNAS OS 6 should all work with RAIDar 6.
- mdgm-ntgrFeb 03, 2016NETGEAR Employee Retired
Well for some legacy models if you choose Flex-RAID using RAIDar 6.x it has ignored the RAID level choice. I don't think that's restricted to very old RAIDiator firmware.
So I would give RAIDar 6.1 a try and if it doesn't do what you want then try RAIDar 4.3.8.
- StephenBFeb 03, 2016Guru - Experienced User
The net is that the OP already did that, and reported that 4.3.8 worked and 6.1 did not. That is why I gave the OP the reply I did.
With all due respect for Kohdee, I think this shows there clearly are some compatibility issues with RAIDar 6 and OS 4 - perhaps not known to Netgear development.
