piechu
Dec 21, 2014Aspirant
Problem with RN102 after 6.2.1 update #24398652
Hello everyone. Today I made an update to version 6.2.1 OS6. I do not know what tempted me, it seemed to me that everything will play as with previous updates. After the update I uninstalled ajax 4. S...
vandermerwe
Dec 21, 2014Master
Regarding not wanting to backup your data: would you be happy of it was all lost, is it easily replaceable?
If you can access the data, then I would first do a backup.
If you are happy to risk data loss, or the data is replaceable easily, then you could try:
Power down and do an OS reinstall using the boot menu:
http://kb.netgear.com/app/answers/detai ... -or-312%3F
An OS reinstall does not wipe the disks, password and network settings will be reset though. It's pretty safe.
Don't do a factory default.
