piechu
Dec 21, 2014Aspirant
Problem with RN102 after 6.2.1 update #24398652
Hello everyone. Today I made an update to version 6.2.1 OS6. I do not know what tempted me, it seemed to me that everything will play as with previous updates. After the update I uninstalled ajax 4. S...
dsnpevl
Dec 22, 2014Virtuoso
dashmesh wrote: All the ports start blinking in tandem.
I have RN516 and also GST108T. Your symptoms match the problems I had exactly. Your 6.2.1 update contains a connman version 1.2.7, that I'm pretty sure is causing the issue. In the thread mentioned below it is suggested that this version of connman is claiming almost all CPU and sending lots of invalid packets that cause your router to fail (and the switch to blink in tandem) and all other network devices to loose connection.
Read more in this thread for a root cause analysis and suggested solution (downgrade to connman 1.26):
viewtopic.php?f=65&t=79118&start=30#p445132
