piechu
Dec 21, 2014Aspirant
Problem with RN102 after 6.2.1 update #24398652
Hello everyone. Today I made an update to version 6.2.1 OS6. I do not know what tempted me, it seemed to me that everything will play as with previous updates. After the update I uninstalled ajax 4. S...
Dec 23, 2014Guru - Experienced User
Fast ethernet is a wash, so there is little speed advantage to switching. USB 3.0 backup speed to NTFS was measured at ~12 MB/s by smallnetbuilder.com. Fast ethernet can run nearly that fast.
piechu wrote: Guys, how can I backup my data?
Is there any free software to manage and copy data from a partition ext packages for Windows7?
StephenB wrote: Copying through windows explorer is actually a lot faster than using the USB 3.0 ports on the RN102 (assuming a gigabit connection).
I do not have a gigabit switch, only fast ethernet.
The net here is that you are losing more time here than you will gain by trying to speed things up. You've already lost 2 days.
I think you should hook things back up the way they were before, and just make the backup the way you did before.
