piechu
Dec 21, 2014Aspirant
Problem with RN102 after 6.2.1 update #24398652
Hello everyone. Today I made an update to version 6.2.1 OS6. I do not know what tempted me, it seemed to me that everything will play as with previous updates. After the update I uninstalled ajax 4. S...
mdgm-ntgr
Dec 24, 2014NETGEAR Employee Retired
Have you looked at the NAS since I rebooted it? I did remove a symlink to a config file that no longer exists that was breaking apache before I rebooted it.
It is in normal mode now.
Provided no one is accessing the system and everything is unmounted you can exit tech support mode by pulling the plug. However it is not in tech support mode any more. I have already rebooted it back to normal mode so if you want to power it down you should power it down safely.
