piechu
Dec 21, 2014Aspirant
Problem with RN102 after 6.2.1 update #24398652
Hello everyone. Today I made an update to version 6.2.1 OS6. I do not know what tempted me, it seemed to me that everything will play as with previous updates. After the update I uninstalled ajax 4. S...
dsnpevl
Dec 25, 2014Virtuoso
mdgm wrote: I removed the symlink the journal indicated was preventing apache2 from starting.
Think I had a similar problem when uninstalling Netgear Surveillance, that I didn't use anyway, but had installed once out of curiosity. After about two minutes into the uninstall, connection was lost to the admin page. Only way to reach the server was through SSH. My website was also down, so the problem had to be related to the web server. Having seen this thread earlier, looked at sites-enabled and saw the symbolic link for 090-surveillance.conf, the application I had just (tried) to remove. After deletion of the symbolic link 090-surveillance.conf -> /apps/surveillance/http.conf and restart of apache and things came back alive. Thanks for sharing your findings! Made my live a bit easier :)
root@nas-XX-XX-XX:/etc/apache2/sites-enabled# ls -al
total 28
drwxr-xr-x 1 115 guest 206 Dec 25 18:12 .
drwxr-xr-x 1 root root 188 Dec 24 10:08 ..
lrwxrwxrwx 1 root root 36 Dec 25 17:29 000-fv-http -> /etc/apache2/sites-available/fv-http
lrwxrwxrwx 1 root root 27 Dec 24 10:08 000-fv-https -> ../sites-available/fv-https
lrwxrwxrwx 1 root root 23 Dec 25 18:12 090-jenkins.conf -> /apps/jenkins/http.conf
lrwxrwxrwx 1 root root 21 Dec 25 18:12 090-koken.conf -> /apps/koken/http.conf
lrwxrwxrwx 1 root root 22 Dec 25 18:12 090-piwigo.conf -> /apps/piwigo/http.conf
lrwxrwxrwx 1 root root 28 Dec 25 18:12 090-surveillance.conf -> /apps/surveillance/http.conf
lrwxrwxrwx 1 root root 36 Oct 11 2013 dsnpevldefault -> /etc/apache2/sites-available/default
root@nas-XX-XX-XX:/etc/apache2/sites-enabled# echo "First test if apache would restart. Restart failed! This proves the problem is related to the Apache configuration."
root@nas-XX-XX-XX:/etc/apache2/sites-enabled# service apache2 restart
[....] Restarting apache2 (via systemctl): apache2.serviceJob failed. See system journal and 'systemctl status' for details.
failed!
root@nas-XX-XX-XX:/etc/apache2/sites-enabled# echo "Check the system. It showed ReadySurveillance failed to uninstall"
root@nas-D5-FE-B8:/etc/apache2/sites-enabled# systemctl status readynasd
readynasd.service - ReadyNAS System Daemon
Loaded: loaded (/lib/systemd/system/readynasd.service; enabled)
Active: active (running) since Thu, 25 Dec 2014 17:38:35 +0100; 1h 9min ago
Main PID: 4020 (readynasd)
Status: "Start Main process"
CGroup: name=systemd:/system/readynasd.service
└ 4020 /usr/sbin/readynasd -v 3 -t
Dec 25 18:12:44 nas-D5-FE-B8 readynasd[4020]: Application 'Media Wiki' is uninstalled successfully.
Dec 25 18:12:46 nas-D5-FE-B8 readynasd[4020]: Cannot send event message. fd=15
Dec 25 18:13:02 nas-D5-FE-B8 readynasd[4020]: Failed to uninstall application 'ReadySurveillance'.
root@nas-XX-XX-XX:/etc/apache2/sites-enabled# echo "Removed the symbolic link of the removed application"
root@nas-XX-XX-XX:/etc/apache2/sites-enabled# rm 090-surveillance.conf
root@nas-XX-XX-XX:/etc/apache2/sites-enabled# echo "Restarted apache once more. Since symbolic link was gone, this restart was succesful."
[ ok ] Restarting apache2 (via systemctl): apache2.service.
