wootcat
Jun 27, 2017Aspirant
Problem with Seagate Backup Plus 4TB and ReadyNAS NV+
I've got an old ReadyNAS NV+ with about 3TB of storage on it. I recently purchased a Seagate Backup Plus 4TB drive to back it up. This is the first time I've connected a USB drive to the NAS with...
- Jul 03, 2017
Try right-clicking on the share and selecting the sharing tab. Then click "advanced sharing".and then "permissions"
If the account you are using to access the share isn't listed, then click on "add" to add it.
Then select that account , and make sure it has all options (full control, change, and read) set to allow.
After that go to the security tab, select that same account, and set all options there (except special permissions) to allow.
Amidala
Jun 28, 2017NETGEAR Employee Retired
it is recommended that you use FAT32 or NTFS file system. You can try it.
