yoda7
Oct 29, 2011Aspirant
Problems accessing over network
Hi Just got my readynas duo which is working fine when connected via the supplied yellow ethernet cable direct to my router. As soon as I use a different network cable (standard straight through...
sphardy1
Oct 29, 2011Apprentice
If the connection fails with a different cable, then immediately that cable must be suspect.
Re. the switch - are you using the same cable that fails when used to replace the original netgear cable? If so, further suggests that cable is at fault
