yoda7
Oct 29, 2011Aspirant
Problems accessing over network
Hi Just got my readynas duo which is working fine when connected via the supplied yellow ethernet cable direct to my router. As soon as I use a different network cable (standard straight through...
sphardy1
Oct 29, 2011Apprentice
IIRC - standard CAT5 cable.
If you truly have tried 23 other cables and none work, then something else is wrong. Possibly the port on the router?
Try a direct connection to rule out router issues: http://sphardy.com/web/directconnect
