MysteryMan1
Sep 10, 2013Aspirant
Problems connecting to shares at Windows startup
I have a ReadyNAS Duo, which has 4 shares set up on it. I have a PC, running W7 and access the shares from that, where I have used the "Map to Network Drive" option to allocate each to a drive lett...
aks
Sep 10, 2013Virtuoso
I have created a similar setup, but only two shares, and I've not noticed this issue. I can try a few more shares when I get to that PC. I have a Duo v1 and NV+ v2.
What unit and software version are you running?
Have you tried adding the credentials under "Manage Network Passwords" (open win7 start menu and start typing)?
