MysteryMan1
Sep 10, 2013Aspirant
Problems connecting to shares at Windows startup
I have a ReadyNAS Duo, which has 4 shares set up on it. I have a PC, running W7 and access the shares from that, where I have used the "Map to Network Drive" option to allocate each to a drive lett...
mdgm-ntgr
Sep 11, 2013NETGEAR Employee Retired
Do you still have the issue if you update to 4.1.12?
