pong1
Apr 17, 2013Aspirant
Problems OS6 and AFP?
after years of finding lots of useful information here i finally gave up guest and registered. i'm not sure this is the right part of the forum but in fact for me os 6 it looks a lot like beta after ...
Leia
Apr 22, 2013NETGEAR Employee Retired
For Bonjour, OS 6 now, it's installed by default. There're 3 services enabled by default: afp, cifs and frontview. And if you turn on timemachine, timemachine will be enabled for bonjour then.
Turn on/off afp or cifs of NAS cannot enable/disable bonjour afp/cifs services.
For access via afp by different users different permissions. Yes, I created 3 users, one RW, one RO and the other no access right. Seems ok for me. Cloud you please point what's failed for you?
mdgm wrote: What about the issue pong mentioned of disabled protocols (SMB/CIFS, Time Machine) still being advertised over Bonjour (i.e. still appearing in the Finder sidebar)?
What about ownership/permissions for AFP shares for different users? Have you tested that?
