pong1
Apr 17, 2013Aspirant
Problems OS6 and AFP?
after years of finding lots of useful information here i finally gave up guest and registered. i'm not sure this is the right part of the forum but in fact for me os 6 it looks a lot like beta after ...
pong1
Apr 22, 2013Aspirant
yep, you're right, when you're connecting with the finder menu it works also with users as i wrote. the problem is, that if you close your finder window with the share, the mount is associated with the wrong item in the sidebar and as soon as you try to go there you get an authorisation failed. so then you have to go over the finder menu "go to folder "/volumes/share" to get access again. not a very user friendly workaround and our customer didn't accept this (which i can understand).
but it's good to hear that there is a internal 6.05 where this is perhaps fixed.
anyways i can't understand how this could slip through quality testing. i found this glitch minutes after first time installation so it's not really a hard to find bug.
