pong1
Apr 17, 2013Aspirant
Problems OS6 and AFP?
after years of finding lots of useful information here i finally gave up guest and registered. i'm not sure this is the right part of the forum but in fact for me os 6 it looks a lot like beta after ...
Leia
May 03, 2013NETGEAR Employee Retired
pong wrote: until they release an update you can take the workaround "finder menu/connect to server" and then don't close the window as written above ;-)
so let's hope there will be an update soon, at least they now could reproduce the problem. when i called tech support, it was totally new for them, so it seems there's some progress.
Actually, no need to do this, please refer to the screenshot:
Tick "Connected servers" in Finder->Preferences->General. Then command+K and login the nas share. A icon for the share will appear in your desktop. You just need to double click to access it.
And cannot login from sidebar issue has been fixed and will be included in 6.0.5.
