pong1
Apr 17, 2013Aspirant
Problems OS6 and AFP?
after years of finding lots of useful information here i finally gave up guest and registered. i'm not sure this is the right part of the forum but in fact for me os 6 it looks a lot like beta after ...
pong1
May 09, 2013Aspirant
with 6.05 out now i did some testing again (thanks chirpa, vm and update works great):
the problem with the sidebar ist gone and user rights seem to work at least for new folders you create.
strange enough there seems to be a problem with the folders created automaticaly (backup, documents, music, ...)
even if you disable anonymous access and also group "everyone" you can see all folders when connecting to the box as guest and you can also access them. is this by design?
btw is it possible to disable the user folders for each created user?
