pong1
Apr 17, 2013Aspirant
Problems OS6 and AFP?
after years of finding lots of useful information here i finally gave up guest and registered. i'm not sure this is the right part of the forum but in fact for me os 6 it looks a lot like beta after ...
Leia
May 10, 2013NETGEAR Employee Retired
pong wrote:
strange enough there seems to be a problem with the folders created automaticaly (backup, documents, music, ...)
even if you disable anonymous access and also group "everyone" you can see all folders when connecting to the box as guest and you can also access them. is this by design?
Which protocol you set permissions for?
If you disable anonymous for SMB, then login with guest via SMB, you can get all shares list, but double click to access it, will be failed.
For AFP, the guest only can see the shares he has at least read right.
Cloud you please describe detail steps?
pong wrote:
btw is it possible to disable the user folders for each created user?
Do you mean you want to not create home directories for users?
