pong1
Apr 17, 2013Aspirant
Problems OS6 and AFP?
after years of finding lots of useful information here i finally gave up guest and registered. i'm not sure this is the right part of the forum but in fact for me os 6 it looks a lot like beta after ...
pong1
May 10, 2013Aspirant
smb was not enabled, only afp. i created a new folder and set the right for my test user, without any right for anybody else, so no guest and no rights for users. it worked as expected. as a guest i can't see the folder, it'S visible only after login. then i set the same rights for the default folders (no guest, no group, only test user) but the folders are all visible and i can also write to backup as a guest, which is strange, because anon access is disabled.
so you mean there are different rights for each protocol? i can configure write access for user test for afp but no rights over smb?
i only found one access setting in the pane.
and yes, i mean disable home folders for users, which is often wanted by our customers.
