pong1
Apr 17, 2013Aspirant
Problems OS6 and AFP?
after years of finding lots of useful information here i finally gave up guest and registered. i'm not sure this is the right part of the forum but in fact for me os 6 it looks a lot like beta after ...
Leia
May 10, 2013NETGEAR Employee Retired
pong wrote: smb was not enabled, only afp. i created a new folder and set the right for my test user, without any right for anybody else, so no guest and no rights for users. it worked as expected. as a guest i can't see the folder, it'S visible only after login. then i set the same rights for the default folders (no guest, no group, only test user) but the folders are all visible and i can also write to backup as a guest, which is strange, because anon access is disabled.
so you mean there are different rights for each protocol? i can configure write access for user test for afp but no rights over smb?
i only found one access setting in the pane.
and yes, i mean disable home folders for users, which is often wanted by our customers.
You can see in Shares->Settings->Access page, there're several tags like SMB/AFP/NFS/FTP/RSYNC/HTTP, click each tag you can go the specific page for each protocol, and you can set whatever permissions you want for the users or groups. So yes, of course you can set a user has write permission for the share via AFP but no rights via SMB. All you need to do is goto the protocol tag, turn it on for this share, and set the user permission.
For disable home folders, it's just no support this now. But we have a plan to enhance home folders thing. I can tell our RD customers want this feature.
