Ingemartin
May 08, 2021Follower
Problems to access ReadyNas remote
Maybe someone can help...i had for many years remote access to my ReadyNAS, but it stopped a few weeks ago. I opened the management for the ReadyNAS, and i see the slide button for remote access is s...
- May 21, 2021
Hi Ingemartin,
ReadyNAS Remote service has been discontinued for years now.
As an alternative, you can use VPN as a way to remotely access your NAS. There are also some 3rd party apps you can use to remotely access your NAS. You may wait for other Community members for suggestions on the apps that you can use.
JohnCM_S
May 25, 2021NETGEAR Employee Retired
Hi Ingemartin,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as a solution so others can be confident in benefiting from the solution.
The NETGEAR community looks forward to hearing from you and being a helpful resource in the future!
