mediator123
Nov 28, 2009Aspirant
Problems using SyncToy 2.1
Hello everyone, I´m almost going crazy with my ReadyNas Duo! Since August I´m trying fix the following problem (with the help of Netgear support), unfortunately without any success! I had a Win...
dbott67
Nov 30, 2009Guide
You're welcome. I also just posted this for someone else, but figured I might as well reproduce it here if you want to configure the Windows machine to be a server and use Frontview to "pull" the data:
1. Install DeltaCopy and configure as a service:
2. Configure any desired Virtual Directories. These are the folders that the ReadyNAS will connect to and backup:
3. Configure Frontview to connect to your Windows PC (using IP address):
4. Set desired parameters, such as destination and schedule.
-Dave
-Dave
